m1noel Posted August 28, 2008 Share Posted August 28, 2008 So After doing a little work under the hood I took off to run some errands. All is fine for a few miles, then the clutch starts to slip. It keeps getting worse as I drive. Babied it home and find that I had bent the clutch line to almost touching the header. I guess as the fluid gets hot-maybe boiling- it builds pressure? DUH. So I bent the line back against the fire wall, flush and bleed, and all is better. Gotta watch that next time. Quote Link to comment Share on other sites More sharing options...
