rwwisnesky Posted August 30, 2008 Share Posted August 30, 2008 I had John's Cars rework the original tach in my 1978 280Z to work with the LS1. My problem is that the Tach jumps all over when I get on it. I am going straight from the computer to the tach via the dash harness. There was a resistor between the old coil and the tach before. Anyone know if I need to keep it between the computer and tha tach??? The tach is fine as long as I rev the engine slowly. Quote Link to comment Share on other sites More sharing options...
m1noel Posted August 31, 2008 Share Posted August 31, 2008 after John's re-re-worked mine (didn't work at all the first time) it now works fine. and there is no resistor installed. I guess the LS2 signal is different than the LS1 though. I would direct a question directly to John and his tach guy. I talked to them and they seemed to know what they were doing. mike Quote Link to comment Share on other sites More sharing options...
rwwisnesky Posted September 2, 2008 Author Share Posted September 2, 2008 I think when I reworked the Z harness, I removed the black ground wire in the C1 connector, thus ungrounding the tach. In the process of reworking it now, hope it works. Quote Link to comment Share on other sites More sharing options...
240zchevyv8 Posted September 2, 2008 Share Posted September 2, 2008 Hello sorry to jump in and hijack the forumn but do any of you guys know how to calibrate the stock 240z tach. I have a 240z that came with the 327 chevy but the tach does not work. I think it requires calibrating but do not know how to do it regards 240z chevy v8. Quote Link to comment Share on other sites More sharing options...
rwwisnesky Posted September 2, 2008 Author Share Posted September 2, 2008 What I do know, which isnt much, it that there is a adjustment screw in the back of the tach. If you have the tack out, hooked up to the engine with a calibrated tach, you should be able to adjust the screw so they read the same. Dont think there is any internal change required. Quote Link to comment Share on other sites More sharing options...
