denny411 Posted January 8, 2002 Share Posted January 8, 2002 I was wondering if anyone had heard of or seen anyway of lowering the second gear in a 700r4 I`m looking to put one behind a 383 that I wan`t to run on the street and strip but,I`m concerned about RPM drop when I hit second ---------DENNY Quote Link to comment Share on other sites More sharing options...
383 240z Posted January 10, 2002 Share Posted January 10, 2002 with the torque of a 383 and the leightweight of a z the rpm drop won't put you into a hole that a motor can't climb out of. The best way to avoid this would be a 2004r but I have a 700 behind my 383 and it works just fine!!! keith Quote Link to comment Share on other sites More sharing options...
biohzrd Posted January 10, 2002 Share Posted January 10, 2002 that has always been the problem with the 700r4. the 1st to 2nd shift was always so big. in a hevier american car say 3300lbs and up it is an issue when you get into anything over the 350 hp/tq mark. in a car as light as a zcar you shouldn't see a big problem. a friend has one in a cobra kit car weighing in at 2650lbs with driver and hasn't had a single problem. and thats with close to 500hp. the 700r4 should hold up fine with the standard performance upgrade. Quote Link to comment Share on other sites More sharing options...
denny411 Posted January 10, 2002 Author Share Posted January 10, 2002 Thanks guys.I kinda thought that might be the case,but wanted some first hand input.Can the 200r4 handle 500+ hp? or are certain years better than others.-------------------DENNY Quote Link to comment Share on other sites More sharing options...
383 240z Posted January 12, 2002 Share Posted January 12, 2002 Just ask ScottieGNZ how well a 200r4 works that was the stock tranny in th buick grand nats. It is a very good trans with a host of aftermarket parts for it they can be bullit proof if built right. Keith Quote Link to comment Share on other sites More sharing options...
