Zreddy Posted September 3, 2008 Share Posted September 3, 2008 I pretty much came up on a short nose r200 from an R32 GTR for free, any chance anyone knows what kind of axles i could prolly use with this setup for my 240z or if i can? Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted September 3, 2008 Share Posted September 3, 2008 You need to first open it up and see if its a CLSD or a VLSD. The r32 GT-R (very early ones) had a CLSD, with the 6 bolt circle input stubs, and they have a larger 31 spline count (if I remember correctly), so your Z axles will not plug into that diff. Â If its a VLSD, I don't know what the spline count is, so you may or (most likely) may not be able to use the Z axles... Quote Link to comment Share on other sites More sharing options...
Zreddy Posted September 3, 2008 Author Share Posted September 3, 2008 You need to first open it up and see if its a CLSD or a VLSD. The r32 GT-R (very early ones) had a CLSD, with the 6 bolt circle input stubs, and they have a larger 31 spline count (if I remember correctly), so your Z axles will not plug into that diff. If its a VLSD, I don't know what the spline count is, so you may or (most likely) may not be able to use the Z axles... it actually looks like a CLSD to me, but i'll try to post pix up to show you guys... I actually picked up some z31 turbo axles, i'll try to do some research and see if those will work. Quote Link to comment Share on other sites More sharing options...
NZeder Posted September 3, 2008 Share Posted September 3, 2008 maybe you could look into something like I am working on. Not sure what size the 6 x 1 cage goes onto but have a look at this thread http://forums.hybridz.org/showthread.php?t=132252&page=4 This way you can use the standard R32 6 x 1 diff output flange/axles with a custom/hybrid setup like I am doing above. Quote Link to comment Share on other sites More sharing options...
