rvandivort Posted September 3, 2008 Share Posted September 3, 2008 Hi, Anyway of reversing this? Thot of prying the thing. I screwed up and put the dots to the inside--didn`t see the U... Family reunion happening!!!.I could just get a premade one. It was a good way of relearning soldering!I`m afraid of putting too much heat to the unit. Also, can You program V3 after assembly, or do you have to go in steps-as per the MS instructions during assembly? We are getting broadband here in two weeks..so the downloads won`t be as long.....still waiting!! Thanks, Roger:confused: Quote Link to comment Share on other sites More sharing options...
rvandivort Posted September 3, 2008 Author Share Posted September 3, 2008 And there is a lot of close soldering on the V3!! Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted September 3, 2008 Share Posted September 3, 2008 Im sorry but i read what you did and im not understanding. Slow down a bit and explain what happened completely Quote Link to comment Share on other sites More sharing options...
rvandivort Posted September 3, 2008 Author Share Posted September 3, 2008 It`s the unit underneath the 6 pin and the power switch..on the right hand side(with the pots on the bottom). Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted September 3, 2008 Share Posted September 3, 2008 More details please. what board? the stim board or the ecu? you mention the "stim ecu" I know the stim board and i know the v3.0 main board. But there isnt a ecu on the stim. Quote Link to comment Share on other sites More sharing options...
rvandivort Posted September 3, 2008 Author Share Posted September 3, 2008 I screwed up and did it backwords--too much distractions! Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted September 3, 2008 Share Posted September 3, 2008 DID what backwards? what number? Like the u3 or d2 or r3 number? Quote Link to comment Share on other sites More sharing options...
rvandivort Posted September 3, 2008 Author Share Posted September 3, 2008 The stim first! The rest..just wanting to know if I can go through the assembly process without checking every stage. In other words, can I program it later? Quote Link to comment Share on other sites More sharing options...
rvandivort Posted September 3, 2008 Author Share Posted September 3, 2008 On the V3 Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted September 3, 2008 Share Posted September 3, 2008 Are you saying you soldered the DB37 backwards? like the one for the stim you put on the ecu. and the one for the ecu on the stim? Quote Link to comment Share on other sites More sharing options...
rvandivort Posted September 3, 2008 Author Share Posted September 3, 2008 NO..I soldered the 16 pin control unit backwords---I`m screwed. Just wondering if there is a way out of My Hell--everything else checked out. Quote Link to comment Share on other sites More sharing options...
rvandivort Posted September 3, 2008 Author Share Posted September 3, 2008 It may be not called an "ecu",but it is the control module as explained above. Under the on /off switch w/ 16 contacts to the board. Quote Link to comment Share on other sites More sharing options...
rvandivort Posted September 3, 2008 Author Share Posted September 3, 2008 I just want to know if there is a way of releasing it from the board..with all the contacts (16)--without damage! If not I`ll just get another one. Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted September 3, 2008 Share Posted September 3, 2008 So why not unsolder it and solder it in the correct way? Just get some solder wick(braided copper wire) Its only 16 pins Quote Link to comment Share on other sites More sharing options...
rvandivort Posted September 3, 2008 Author Share Posted September 3, 2008 Also ,there was the question about the V3 board and delaying programming until total assemby. Quote Link to comment Share on other sites More sharing options...
rvandivort Posted September 3, 2008 Author Share Posted September 3, 2008 So, Jeffers..are You telling Me I can`t hurt the thing by excessive heat? Thanks! What is solder wick?..use 22 g copper stranded wire?, tryed suction. Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted September 3, 2008 Share Posted September 3, 2008 http://www.radioshack.com/search/index.jsp?kw=desoldering+braid regular stranded wire wont work. you should be able to pick up the wick at any radio shack. If you want a more mechanical way. go with this http://www.radioshack.com/product/index.jsp?productId=2062731&cp=&sr=1&origkw=desoldering&kw=desoldering&parentPage=search Quote Link to comment Share on other sites More sharing options...
rvandivort Posted September 3, 2008 Author Share Posted September 3, 2008 I tried to do this thing by laying down the soldering iron horizontally across each side, waiting, and then pulling up.I`m trying to find a way to solve this problem.How does the solder wick work? Quote Link to comment Share on other sites More sharing options...
rvandivort Posted September 3, 2008 Author Share Posted September 3, 2008 Ok, saw the RS thing. I have suction..the only question I have is-how much heat can I apply? Quote Link to comment Share on other sites More sharing options...
rvandivort Posted September 3, 2008 Author Share Posted September 3, 2008 without destroying it. Quote Link to comment Share on other sites More sharing options...
