stim ecu reversed,programing for V3
rvandivort
Hi, Anyway of reversing this? Thot of prying the thing. I screwed up and put the dots to the inside--didn`t see the U... Family reunion happening!!!.I could just get a premade one. It was a good way of relearning soldering!I`m afraid of putting too much heat to the unit. Also, can You program V3 after assembly, or do you have to go in steps-as per the MS instructions during assembly? We are getting broadband here in two weeks..so the downloads won`t be as long.....still waiting!! Thanks, Roger:confused:
http://www.radioshack.com/search/index.jsp?kw=desoldering+braid
regular stranded wire wont work. you should be able to pick up the wick at any radio shack.
If you want a more mechanical way. go with this
http://www.radioshack.com/product/index.jsp?productId=2062731&cp=&sr=1&origkw=desoldering&kw=desoldering&parentPage=search
