lgoodson@pacbell.net Posted September 3, 2008 Share Posted September 3, 2008 What is it and where do I get it. I am trying to stop this oil leak that I have fighting for over a year now. Thanks Quote Link to comment Share on other sites More sharing options...
Ferrariferg Posted September 3, 2008 Share Posted September 3, 2008 I think UV Dye is for AC systems. Not sure they have it for oil. Could be wrong though. Check your local auto parts. Quote Link to comment Share on other sites More sharing options...
datsun723 Posted September 3, 2008 Share Posted September 3, 2008 sorry i can't answer your question, but i jus wanted to say that I too am in orange county you have a cardomain page?? Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted September 3, 2008 Share Posted September 3, 2008 Yes you can add UV dye to your engine oil. It will help you find intermittent or seeping oil leaks. If it is a bigger leak, just clean all the old oil and crud off. Then run it hot and see where she flows. BTW you need a UV light to see the dye. Quote Link to comment Share on other sites More sharing options...
jbk240z Posted September 3, 2008 Share Posted September 3, 2008 I used to work at Pep Boys and we had the dye in the service dept. You can try asking the service guys about it. I know I sold a few vials of the dye. The dye was inexspensive IIRC. Good luck. An ordinary black light bulb should work for tracing the leak. Easy to find come Halloween. Quote Link to comment Share on other sites More sharing options...
