3 point retractable seat belts
jerryb
Now that I have my Solstice seats installed Im going to move away from the 4 point style cam lock racing belts to a simpler set up.
Ive decided on 3 point retractable belts and will go with on of these manufacturers...
http://www.seatbeltsplus.com/mm5/merchant.mvc?Screen=PROD&Store_Code=sbp&Product_Code=WSCH300&Category_Code=3-Point-Retractable-Seat-Belts
http://wescoperformance.stores.yahoo.net/resebe.html
http://www.ssnake-oyl.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=Ssnake-Oyl&Category_Code=CSB
Im leaning towards SSnake-Oyl because they will customize....I like the satin metal lift release and I may go with yellow stitching.
Anyway.....does anyone have experience with any of these companies? Or has anyone recently installed aftermarket 3 point retractables?
  • 4 weeks later...
Do you recall the brand Mike?
Thanx!!
I installed some three point belts in my '71 240. The only place to locate the retractable mechanism was in front of the rear wheel housings. I placed a plate underneath the metal deck via the storage compartments for reinforcement. See attached picture.
Mike Mileski
Tucson, AZ
I was originally going to get them from Juliano's, who specialize in street rods, but I ended up just getting them on ebay. I don't recall the brand. The only problem is that, when they are fully retracted, there's still some slack in them. In other words, they don't retract all the way into the portion you see in the picture, I guess its because the exposed portion, when mounted into a Datsun, is much shorter than in standard applications. They still work fine, though. You will also need to buy some 7/16 fine thread eyebolts that thread into the stock Datsun mounting points to help you adapt these.
http://search.store.yahoo.net/cgi-bin/nsearch?catalog=wescoperformance&query=rjs-101&.autodone=http://store.yahoo.net/wescoperformance/nsearch.html
Mike Mileski
Tucson, AZ
