Dorman T5 Clutch Slave Cylinder
Miles
Has anyone used the Dorman aluminum clutch slave cylinder for the T5? I have used a plastic Napa (UP 37821) T5 clutch slave, but was always concerned that it would melt from from it's proximity to the header.
The Dorman is Summit part number DHB-CS37821 $49.95
http://store.summitracing.com/egnsearch.asp?Ntk=KeywordSearch&DDS=1&Ntt=cs37821&searchinresults=false&N=700+115&y=3&x=34
I'll use the McLeod clutch hose roll pin adaptor and a 24 or 26 inch -4 line to connect it to a Tilton 7/8" clutch master cylinder.
Brain fart: I took apart an old T5 clutch hydraulic hose and removed the roll pin connector. It is just a hose barb pressed into the hose. Anyone ever make up a clutch hose using the T5 barbed roll pin connector from a wrecking yard?
Miles
