Dave Posted September 12, 2008 Share Posted September 12, 2008 I have spent the last 2 days searching for any reference to swapping the 77-8 280Z rear brakes for what is stock on my 71 240Z. My motive is 69-76 wheel cylinders are $150-$200 a pair, 77-78 are $12-$25 a pair and are stocked everywhere. I have the complete backing plates from a 77-8 Z and see no reason why they will not work. I realize I need to pull the axles to swap this stuff over. Am I missing something since I can't find anything about this being done before on the 240Z? I have swapped the front for 300ZX rotors and 280ZX calipers and I used the 280ZX master cylinder and am still using the stock drums on the rear and every thing works. the wheels are 6 spoke 280ZX. The last hurdle is to fix a leaking stock rear wheel cylinder. Quote Link to comment Share on other sites More sharing options...
blue72 Posted September 12, 2008 Share Posted September 12, 2008 The Nissan cylinders are a little pricey, but I think it was worth it. Mine were $76 each, genuine Nissan, and ordered from a Carquest auto parts store. I have a '72, so it is the same part number. I just checked the Autozone website, and they listed off brand ones for $23 a piece. Maybe some more searching might prove useful. Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted September 14, 2008 Share Posted September 14, 2008 I ran the 280z rear drums on my 240 for about 5 years. They seem to stay in adjustment longer. I had no problems at all with the installation. Doug Quote Link to comment Share on other sites More sharing options...
evildky Posted September 15, 2008 Share Posted September 15, 2008 they bolt right on, you will need the brake hardline that goes form the slage tot he rubber line, on the 240 the slave it att he top of the assy and the 280 it's at the bottom, kinda tired I might have taht reversed but you'll see when you look at them, only the 77-78 got the dual piston setup, thall the earlier cars got the single setup Quote Link to comment Share on other sites More sharing options...
Challenger Posted September 15, 2008 Share Posted September 15, 2008 Ive got a 280z rear drum assembly Ill sell. The drums were turned and the shoes are newer. Ill include all the little pieces that I pulled off for rear disk conversion. (shoes, piston/cylinder, brake line, springs) All the brakes were redone a few years ago and its just sat. Quote Link to comment Share on other sites More sharing options...
