Sudden clutch slippage
X64v
Last night I did two mildly-hard launches getting 0-60 times. The first time the clutch caught and bogged the motor, the second time the clutch caught and spun the tires, so the clutch wasn't slipping all that much either time. Well, after the second run, now the clutch slips fairly badly in 4th gear at full boost, causing it to chatter and make the whole rear end vibrate like a cell phone x1000. It doesn't do this in any other gear besides 4th at full boost (which makes somewhere between 240-280ft. lbs. with my setup). I'm running a 225mm clutchnet 6-puck sprung disk with the stock flywheel and pressure plate. My clutch pedal engagement feel and travel didn't change, around town everything is normal. Does anyone have any insight to what this might be? Burned up disk? Pressure plate not clamping hard enough? I know I'm going to have to tear it apart, I'm just trying to get a feel for what might be wrong before I do.
