RB26 Transmission bolts size?
amorfin
yep, they are nissan part numbers out of FAST. some may be superceded.. but nissan will be able to sort that out (i just bought and fitted all of these myself).
and yes, that is every bolt (and Nut) to bolt the Transmission (either RB25 or RB26) to the RB26DETT.. if you are not using the RB26DETT sump, i am not sure if you can use the RB25DET bottom gearbox mounting plates, but either way you need all these bolts.
Kent
