V-Band Size
Noddle
  jeffer949 said:
Read again. Not what motor. What turbo. Is it a holset?
no, it's a Chinese one I believe, .50 AR Compressor, .63 AR Turbine, .57 Trim, non water cooled.
it should do what I want from it.
still my question, where is the measurement taken from, the outer lip ?
Nigel
You can roughly measure the diameter of the turbine just behind that lip and get what size piping (and v-band) will work with it. That being said, it's Chinese, so... good luck. If "doing what you want from it" includes grenading and feeding little bits of hard stuff into your oil then you should be set. :icon14:
But that's been....:beatdeadh
