starter problem after l28et swap
Ok I am using a completely stock turbo block, a 5 speed tranny from a 83 280zx 2+2 n/a and my stock flywheel from the n/a.
Everything is in the car and hooked up and when i try to start the car my starter will kick out and spin but barely catch the flywheel and just grind on the edge.
I'm using the starter from my 83 n/a and i didn't think there was any real difference between the turbo on and it.
Anybody have a clue whats going on here?
Well after poking around i'm pretty sure i figured out what it was.
The turbo motor was an auto setup and i removed the flexplate off the block but there still seems to be a shiny spacer thats sitting between the crank and my flywheel and that wasn't the case with my n/a 5 speed setup.
am i right here?
