slyhog22056 Posted October 10, 2008 Share Posted October 10, 2008 Ok, got my 500 Z engine ready and trying to install all the front end stuff but cant find the correct length belt to drive the waterpump and alternator. I need a 6 rib serpentine belt, 1" wide and 38 3/4" to 39 1/2" in length. Been searching all over the net and cant seem to find anything even close. Does anyone know a source, connection or even where to find 4 hole v belt pulleys for the crankshaft?? I will change to v belts if necesary. The crank pulley has to be the outer one of the 2 with a dish of 1 1/2" to 1 5/8" to the inside edge. Link to comment Share on other sites More sharing options...
Trevor Posted October 10, 2008 Share Posted October 10, 2008 Boy, that's a short belt. Most Part# system for Serp belts is 060000 (6 rib belt, followed by 3 places for whole inches and one decimal) this part might work: Gates K060388 for Honda; Civic; 2005-2001; 4-Cyl. 1.7 Eng.; Alt & AC 13/16" x 39 3/8" Dayton is a K60388 to K60395 The NAPA parts you want a number between 25-060388 and 25-060395 DAYCO parts are similar, DY 5060380 is a 6-rib 38.0" long. Try looking for a number from DY5060388 to DY05060395 Good luck! Link to comment Share on other sites More sharing options...
slyhog22056 Posted October 11, 2008 Author Share Posted October 11, 2008 Well went to pepboys and fount they have a 39" belt but not the 38" version. Got it home and realized it measures 40" so i remounted the alternator and made it work, sure hope it dont interfere with anything hanging that low once i install the motor in the 500 Z Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted October 11, 2008 Share Posted October 11, 2008 Silly question: Do you have a forward rotation water pump on that motor? The factory water pumps that came in the 1982-1995 mustang had reverse rotation water pumps (the water pump and crank shaft rotated in opposite directions). If you try to turn the reverse rotation pump in the forward direction, then it will not pump water properly through the engine. With a reverse rotation pump, you need an idler pulley to control the belt tension and to provide belt contact around the water pump pulley. Here is my solution: The tensioner pulley came from Steeda, the mounting brackets for the tensioner are custom, and the belt is 49.5 inches. If you decide to go with Vee belts, try march performance. They have a very wide selection of pulleys and brackets (both vee belt and serpentine). Your alternator mounting should be fine. Mine is mounted with the centerline if the alternator pulley lower than the centeline of the crank pulley. I have about 1/4" between the alternator and the boot on the steering rack. Link to comment Share on other sites More sharing options...
slyhog22056 Posted October 13, 2008 Author Share Posted October 13, 2008 Well i believe it will work then especially since yours is a lot lower than mine, this is a lincoln towncar 302 and has a 6 rib pulley so i am assuming the belt inside runs around the pulley. if it was a smooth pulley i could understand running under it with the outside of the belt with a tensioner. Link to comment Share on other sites More sharing options...
Trevor Posted October 13, 2008 Share Posted October 13, 2008 Lincoln town car 302 is a "normal" rotation water pump. Link to comment Share on other sites More sharing options...
grumpyvette Posted October 13, 2008 Share Posted October 13, 2008 just as a point of interest, its not all that difficult to fabricate an adjustable belt tensioner and a coaster wheel bracket for serpintine belt drives, or to get one from a salvage yard that can be modified to fit and work correcly Link to comment Share on other sites More sharing options...
