jleturgey Posted October 20, 2008 Share Posted October 20, 2008 i just got my hands on a r200 long nose 4:36to1 gear lsd i want to put in my chevy powerd early 260z, the axle has 29 splines i dont have a clue as what my next move should be any help would be great Quote Link to comment Share on other sites More sharing options...
reddzx Posted March 3, 2009 Share Posted March 3, 2009 87-89 300ZX turbo shafts Quote Link to comment Share on other sites More sharing options...
rsicard Posted March 3, 2009 Share Posted March 3, 2009 Also replace the 260Z Stub Axles with either 280Z Stub Axles or Modern Motorsports Stub Axles + inner adapters for 87-89 300ZX Turbo Half Shafts. Modern Motorsports has the REAL BEEFY Stub Axles and lesser Beefy Stub Axles. Just depends upon how much horsepower and Torque are transmitted through the stub axles. Also there is a forward or nose mount for the differential on this forum to SOLIDLY mount the nose against torque wrapup. Finally, you may need a 280Z Mustache Bar. I have the REAL BEEFY Modern Motorsports Stub Axles, the 87-89 Turbo 300ZX Half Shafts, front nose mount and 280Z Mustache Bar. While modifying, use Poly Bushings. Search through the forums on this subject. Quote Link to comment Share on other sites More sharing options...
jleturgey Posted March 3, 2009 Author Share Posted March 3, 2009 Also replace the 260Z Stub Axles with either 280Z Stub Axles or Modern Motorsports Stub Axles + inner adapters for 87-89 300ZX Turbo Half Shafts. Modern Motorsports has the REAL BEEFY Stub Axles and lesser Beefy Stub Axles. Just depends upon how much horsepower and Torque are transmitted through the stub axles. Also there is a forward or nose mount for the differential on this forum to SOLIDLY mount the nose against torque wrapup. Finally, you may need a 280Z Mustache Bar. I have the REAL BEEFY Modern Motorsports Stub Axles, the 87-89 Turbo 300ZX Half Shafts, front nose mount and 280Z Mustache Bar. While modifying, use Poly Bushings. Search through the forums on this subject. thanks for the reply, i purchased the inner stubs and cv axles from wolfcreek billet suspension from azc also a solid diff frnt mt from azc. i guess i'll be breaking some parts Quote Link to comment Share on other sites More sharing options...
