Turbo distributor shaft orientation at TDC
zane9000
  • 6 months later...
So you guys go by the rotor rather than looking at the orientation of the top of the shaft as the book and FSM do? So as long as the rotor is facing straight ahead at TDC everything is good? We are having issue with this and need a concrete answer. Thanks guys!
I hope I remember this right... If you pull off the distributor and look at the top of the shaft it should be at a 5 degree angle counter clockwise from a line intersecting the distributor mounting holes with the little half towards the front of the car.
