Guest Anonymous Posted April 10, 2002 Share Posted April 10, 2002 hey guys. my car is a 1976 datsun 280z mostly stock right now. For a while i have had a bizzare rear end clunk when i let off the gas sharply in a low rpm. It is a 5spd manual transmission+overdrive. Specs say that this year car comes with r200 if tranny is not automatic. I looked under and differential is mounted on top of this ugly welded thing(about 6-7 steel plates in a stack). what is the mount supposed to look like? What could be the noise source? Is the upper strap supposed to be tight? If not mount or srap what else should i check... thanks Quote Link to comment Share on other sites More sharing options...
auxilary Posted April 10, 2002 Share Posted April 10, 2002 you're looking at a balancing plate that weighs about 15 lbs. It's attached on the bottom of the front rear diff crossmember. mounted on top of the front reardiff crossmember is (if you're looking from the bottom) is a metal case that looks like a U from the side, and it's filled with rubber. When the rubber breaks or tears, your differential clunks every time it twists from the rotational force. Because there's no mount properly securing it and dampening the shock. solution is to get a new mount. they're 50-60 bucks from MSA, i think Quote Link to comment Share on other sites More sharing options...
fl327 Posted April 10, 2002 Share Posted April 10, 2002 dealership sells part for 49.99 after tax, should have it in stock. Quote Link to comment Share on other sites More sharing options...
fl327 Posted April 12, 2002 Share Posted April 12, 2002 if youre in the area, motorsport would be the way to go. Quote Link to comment Share on other sites More sharing options...
Guest mtj71Z Posted April 12, 2002 Share Posted April 12, 2002 could a mustache bar bushing cause a clunk when you let off the gas? Quote Link to comment Share on other sites More sharing options...
auxilary Posted April 12, 2002 Share Posted April 12, 2002 actually, just checked msa catalog - 41.99 Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 15, 2002 Share Posted April 15, 2002 check it... what is the msa? where do i get it? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 16, 2002 Share Posted April 16, 2002 1-800-633-6331 for MOTORSPORT AUTO (MSA) and 1-800-255-0088 for Victoria British LTD for free catalogs for The DATSUNS VICTORIA BRITISH and MSA have some great detailed and exploded diagrams to identify Datsun parts Quote Link to comment Share on other sites More sharing options...
