2eighTZ4me Posted October 22, 2008 Share Posted October 22, 2008 I have AutoMeter Ultra Light gauges. The sending unit I have for both water temp and oil temp measures .567" (roughly) diameter at 1 3/4" long. I am trying to order an inline oil temp gauge adapter from Pegasus Racing, such that I can just screw the sensor in and get readings from the line. The water unit actually screws into the t-stat housing fine. It is the same size as the oil sending unit. (Sensors look identical). I have been researching on Summit's website and only can seem to find 3/8" and 1/2" adapters. Can someone confirm the size I need to get, as .567" comes out to roughly 9/16" and I don't see that listed anywhere. Pegasus racing recommends that if I'm using AutoMeter gauges, that I will need a 5/8 - 18 adapter, yet 5/8" comes out to .625". Am I measuring wrong? I measured the threaded part OD in between the threads. Quote Link to comment Share on other sites More sharing options...
darom Posted October 23, 2008 Share Posted October 23, 2008 The source mentions the size: http://datsunzgarage.com/rebuild/ "... the correct thread for the oil sensor hole on the passenger side of the block is 1/8" -18 NPT (National Pipe Thread)." My 280z 1976 block had a British Pipe Thread (BPT) oil adapter. I ordered an Autometer sender/gauge and had to find an inline adapter BPT male to national pipe thread female for the Autometer sender. Quote Link to comment Share on other sites More sharing options...
2eighTZ4me Posted October 23, 2008 Author Share Posted October 23, 2008 That's the pressure sender - not temperature. Already got the pressure fitting taken care of and plumbed. I figured it out though. I was indeed measuring wrong. I needed to measure at the crown of the threads, not in between. Pegasus was correct, for an AutoMeter TEMP sending gauge, the size is 5/8 x 18. Quote Link to comment Share on other sites More sharing options...
