philipl Posted October 27, 2008 Share Posted October 27, 2008 Curious as to wether or not anyone knows of any clearence issues or :biggrin:problems with e brake and cv shafts on the maxima bracket and zx rear caliper upgrade on a 240.I JUST WANT TO BE SURE BEFORE I PLUNGE IN I HAVE ALREADY PURCHASED THE CV PARTS!!! ANY INPUT IS GREATLY WELCOME..............ALSO CAR WILL BE LOWERED WITH STANDERD LOWERING SPRINGS 1"............ Quote Link to comment Share on other sites More sharing options...
evildky Posted October 31, 2008 Share Posted October 31, 2008 I had the 280/max brake swap with z31 cv's and had no clearance issues, the e-brake cables need to be moved a bit but no biggie, the sway bar end links had to be cut down to clear the cv's but otherwise trouble free Quote Link to comment Share on other sites More sharing options...
philipl Posted October 31, 2008 Author Share Posted October 31, 2008 thanks any issues with cvs bottoming out on your setup is it true you need two lefts because there shorter or is this a myth........thanks phil Quote Link to comment Share on other sites More sharing options...
