84-86 T5
Mike C
IN looking through my Chiltons manual, they show a torque sequence for the 83 and earlier bellhousing and the 84 and up. The newer one seems to have the same bolt pattern with some additional bolts, but the starter clearance bump is rotated around to the bottom. If the input shaft is same length then you could use the 83 bellhousing, but you'd still have to find an 83 trans.
