Guest Anonymous Posted May 8, 2002 Share Posted May 8, 2002 Hi guys, Question regarding the rear diff cover gasket on a R200 diff. Do/should I get a gasket or can I use a high-temp RTV or permatex #1 or #2 and forget the gasket? Thanks. Jon Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 8, 2002 Share Posted May 8, 2002 Buy a sheet of gasket material and make your own gasket useing the cover plate as a template. get a correct size hole punch unless a common paper punch is close to the bolt diameter. I just don't like that RTV sealant and prefer the old non-hardening gasket sealers that look like black tar. a sheet of gasket material goes along way. If it had a gasket put a gasket back on. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 8, 2002 Share Posted May 8, 2002 Thanks T, it had a gasket but it was distroyed removing the cover. I wasn't clear in my question, but what I wanted to know was if anyone has used a flange sealing compound in leiu of a gasket. If the factory gasket or equivelent is what I should do I'll do it. I was just wondering if using a gasket was old school (where I come from) or if there was a modern equivelent. Thanks. jon Quote Link to comment Share on other sites More sharing options...
QWKDTSN Posted May 8, 2002 Share Posted May 8, 2002 Get gasket maker. I bought my diff from All Z Auto Wrecking and Lee (one of the owners) pulled apart my diff to let me see the internals. He put in new oil and squirted a fat bead of this blue silicone stuff on the mating surfaces, let it set for a minute or two, and torqued it to spec. No leaking problems. I'm not sure exactly what he used but it looked like real good stuff. Quote Link to comment Share on other sites More sharing options...
R0N Posted May 8, 2002 Share Posted May 8, 2002 John, I would just get one from the dealer, save the pain and spendless time putting the cover on. Oh and no mess. No need to go aftermarket on diff covers. Just my 2 cents. Quote Link to comment Share on other sites More sharing options...
fl327 Posted May 8, 2002 Share Posted May 8, 2002 i took it easy when i pulled the cover, broke the gasket, put it back on and used black rtv on the lip and slapped it back on, doesnt leak, i was lucky. buying the gasket is good insurance, cause i think you have to dang near drop the stinky differential just to change it, and you dont want to do that. Quote Link to comment Share on other sites More sharing options...
utvolman99 Posted May 8, 2002 Share Posted May 8, 2002 buy a gasket, mine was $5 at Advanced. I also used a thin coat of RTV on the bottom half of the case. I really dont want any leaks. JM2cents Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 9, 2002 Share Posted May 9, 2002 Thanks guys. I'll do the right thing and not cheap out. Thanks for the input. Jon Quote Link to comment Share on other sites More sharing options...
