Maybe a stupid EDIS question but...
pallnet
Maybe it's been covered before and I read over it without noticing the info I need but what happens to the EDIS system if it does not see the missing tooth on the reluctor wheel? Lets just say it's reading teeth all the time because there is no missing tooth.
I know this is an off the wall question but it popped into my head and I can't seem to find the answer. Keep in mind that I havn't hooked anything up just yet and the setup I want to put together involves an SDS "E" system running off a 82-83 cas unit. I want to tie the EDIS system into the SDS to get cheaper (not cheap because I paid a chunk for the SDS system a while back) DIS ignition.
You guys feem to know EDIS fairly well so I figured I would ask here.
Thanks
pallnet
