71 240z signal light problem....
O.k. I know my way around cars fairly good, but I have an issue.
I am tring to get a saftey on the car, but the signals won't work.
I can not get my right side front flasher to work. The left side works no problem, the park lights all work, the 4ways work, dim, but work.
I have checked all the wiring back to the harness and it all looks o.k.
I pull down the lever and the left is flashing, I hear the flasher clicking, the dash light is on. I lift up nothin! No sound, lights etc...
Is there any way to bypass the column lever to check to see if it is that?
HELP PLEASE......
I have had this same problem in 3 of my 240z's. It is almost always just a worn out turn signal lever. Try to push it up hard and then wiggle it back and forth a little. That usually does the trick on mine. It even does it sometimes on my brand new assembly. However that only works if they are just worn a little, if yours does not make contact at all this will not work.
Kevin
Kevin
NADDA. Thanks
