Help! Light Bulb Are Blowing Up!
Check for high voltage output , possibly caused by a bad voltage regulator. norm... approx 12-14 volts. over 14.3.......BAD . check at all rpm ranges and loads on system. Make sure battery terminals are CLEAN AND TIGHT.
That. check the voltage with a multimeter; if it is over 14 the voltage regulator is bad.
