aarang Posted December 21, 2008 Share Posted December 21, 2008 You will find that the majority of the Nissan turbine housings will be cracked in a similar way. I have four of them and they are all cracked. I have been told that if they do not leak, to just use them. You may be able to find one off of a Z31, that is what I did, as they seem to not crack as severely as the 280ZXT ones. Hope that helps. Aaron Quote Link to comment Share on other sites More sharing options...
zbigtim Posted December 21, 2008 Author Share Posted December 21, 2008 Thanks for you reply's, guys. That really makes me feel a lot better... Quote Link to comment Share on other sites More sharing options...
zbigtim Posted December 21, 2008 Author Share Posted December 21, 2008 Quote Remove the compressor wheel. They can gall on the shaft if you have to turn it alot without it slowly coming off. Once it's off, lightly tap on the threaded end of the shaft and the turbine will pop out. The only that that will be giving resistance is the piston ring on the end of the turbine wheel. You just need enough force to pop that out. Same with putting it back in just make sure you have the ring seated as far as it will go into the chamfer in the center housing. Use the T4 heat shield with the T4 wheel too. Would I not want to use the T3 wheel and shield. The T4 is not going to fit inside the T3 exhaust housing, will it? Quote Link to comment Share on other sites More sharing options...
zbigtim Posted December 22, 2008 Author Share Posted December 22, 2008 I have disassembled both turbos and are comparing the parts. It looks like I need to take the exhaust turbine off the T3 shaft and install it on the new T4 shaft. The T4 shaft has a longer thread (left handed thread) than the T3 on the compressor side. Is this something I can do in my own garage? What about balancing the assembly? Quote Link to comment Share on other sites More sharing options...
djz Posted December 24, 2008 Share Posted December 24, 2008 The exhaust wheels don't come off the shafts, try assembling everything using the T04 compressor section and the T3 rear section, the thread is longer but it looks like the rest of the shaft is the same length, pretty sure it'll work okay. You should get it balanced. zbigtim said: I have disassembled both turbos and are comparing the parts. It looks like I need to take the exhaust turbine off the T3 shaft and install it on the new T4 shaft. The T4 shaft has a longer thread (left handed thread) than the T3 on the compressor side. Is this something I can do in my own garage? What about balancing the assembly? Quote Link to comment Share on other sites More sharing options...
Clifton Posted December 24, 2008 Share Posted December 24, 2008 djz said: You should get it balanced. Compressor and turbine wheels are balanced individually. Unless it came from an aftermarket shop like Turbonetics it won't matter. Even they just take the weight off the compressor nut. I've mixed and matched their parts without problems. New nut of coarse. Quote Link to comment Share on other sites More sharing options...
zbigtim Posted December 24, 2008 Author Share Posted December 24, 2008 Quote The exhaust wheels don't come off the shafts, try assembling everything using the T04 compressor section and the T3 rear section, the thread is longer but it looks like the rest of the shaft is the same length, pretty sure it'll work okay. You should get it balanced. Thank you, that is what I'll try. I think you're right. There was some side to side play in the T3, before I disassembled. Do you think that the bearings in the center section is what wears, or do I need to worry about the shaft. I will mic the shaft today and compare to the newer T4 shaft. Quote Compressor and turbine wheels are balanced individually. Unless it came from an aftermarket shop like Turbonetics it won't matter. Even they just take the weight off the compressor nut. I've mixed and matched their parts without problems. New nut of coarse. Yes, you can see on the backside of the compressor wheel where it was balanced, and I will definitely use a new nut. As a note; the T4 shaft has a left hand thread, and looking at the rotation of the shaft, this makes sense. Anybody have issues with the nut loosening on the T3? Quote Link to comment Share on other sites More sharing options...
