Mike Rowe Posted November 17, 2008 Share Posted November 17, 2008 Hi guys, how have others connected the fuel line from the tank to the fuel regulator? The standard fitting is a piece of fuel hose between the hard line and the regulator. (see photo 1 & 2) I am going to run stainless steel covered -6 hose from my surge tank through to the front. On each end I want to run AN fittings. As I am fitting the Nismo adjustable fuel regulator I was wondering if anyone had welded an AN fitting on the tube (see reg photo RHS photo) so that it can be screwed to the s/s fuel delivery hose and like wise with the return line. Has anyone done this? Or what other ways have you got rid of the rubber hose & clamps? Quote Link to comment Share on other sites More sharing options...
Booztd 3 Posted November 18, 2008 Share Posted November 18, 2008 Hi guys, how have others connected the fuel line from the tank to the fuel regulator? The standard fitting is a piece of fuel hose between the hard line and the regulator. (see photo 1 & 2)I am going to run stainless steel covered -6 hose from my surge tank through to the front. On each end I want to run AN fittings. As I am fitting the Nismo adjustable fuel regulator I was wondering if anyone had welded an AN fitting on the tube (see reg photo RHS photo) so that it can be screwed to the s/s fuel delivery hose and like wise with the return line. Has anyone done this? Or what other ways have you got rid of the rubber hose & clamps? You could cut off the flared end of the regulator and Earls makes a compression fitting that converts to AN-6 Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted November 19, 2008 Author Share Posted November 19, 2008 thanks Booztd3. I have found an Earls fitting that will allow me to mate the s/s hose up to the fitting Quote Link to comment Share on other sites More sharing options...
