madkaw Posted November 18, 2008 Share Posted November 18, 2008 Probably too much info in the title, but I tried to cover it all:-D I have recently done my complete 4 wheel wildwood brake set up and can't be happier. I was doing a lot searching the other day about pedal travel and adjustments and stumbled on a possible screw up by me. I noticed after the fact that I was suppose to switch around lines to the master since the ZX master is different as far as front and rear reservoir. My stupid question is that can you just swap out the reserviors on the top of the master and put the larger tank for the fronts? maybe I am not understanding the internals of the master completely, but is there a difference internally? Is it just the reserviors? . Now the ZX 15/16 MC was made for 4 wheel disc or not? What would be the effect of just swapping the reserviors and not the lines? Is not the pressure the same at all corners just regulated by the proportioning valve? Any help in understanding this would be great. Quote Link to comment Share on other sites More sharing options...
Spooler Posted November 18, 2008 Share Posted November 18, 2008 I don't think it matters. If it is working good then leave it alone. I have the same setup coming..... I can't seem to locate a 15/16 79-81 zx master cylinder though...... Quote Link to comment Share on other sites More sharing options...
