No headlights
74 Datsun 260z. Have no headlights. Guage lights and marker lights all work properly, just no headlamps. I've pulled the switch, rebuilt it and I have power to all four points when the lever is all the way in the on position. But no lights. So I'm going to look at the ground wire and hopefully that's it. Anyone know what color it is and where it grounds to the body/frame?
  • 4 months later...
  • 4 weeks later...
The switch that controls your headlights (the combination switch) is likely kaput. All the juice running through them kills them rather quick unless you get a headlight relay harness.
Is there a way to rebuild the combination switch? My left headlight is out, and I think it might be the switch. The left high beam works fine, but the low beam does not work.
Problem solved. The high beam switch wasn't making its internal connection between any of the contacts, once that was solved, pretso! Lights work. Now it's on to the head gasket which I think I blew this afternoon. Great times.
