Clifton Posted December 3, 2008 Share Posted December 3, 2008 I think I'm done with SDS. I already have a good coil and MSD 6a. It would be easier to keep it and go with a 83' dizzy with MS. I wouldn't have to pull the damper and mod it. Any reason not to keep this over the edis/ wastespark? I know it works good as I run it on another car but I have not seen any posts on comparing the two on MS. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted December 4, 2008 Share Posted December 4, 2008 I can't really think of a good reason to go EDIS since you already have the setup for 83 dizzy and MSD. I suppose you will get a little more jitter in the spark timing with the dizzy, but for all practical purposes I say save some money/time and stay with what you have. That makes for an easy straight forward megasquirt intall, at least in theory Quote Link to comment Share on other sites More sharing options...
Clifton Posted December 4, 2008 Author Share Posted December 4, 2008 Thanks Moby. I actually have a 77 dizzy. If it is just as easy to hook up, I won't go edis. It's alot easy not pulling the damper off and fabbing the trigger/wheel mount. Quote Link to comment Share on other sites More sharing options...
letitsnow Posted December 5, 2008 Share Posted December 5, 2008 Thanks Moby. I actually have a 77 dizzy. If it is just as easy to hook up, I won't go edis. It's alot easy not pulling the damper off and fabbing the trigger/wheel mount. The '77 dizzy can trigger MS, you have to lock it down and include the VR circuit on the MS board. Quote Link to comment Share on other sites More sharing options...
Clifton Posted December 5, 2008 Author Share Posted December 5, 2008 Cool. It's been locked down way before I had SDS so it will be an easy swap. Quote Link to comment Share on other sites More sharing options...
