P90 Valve Stem Length
zbigtim
The valve stems are .080 longer in the n-47 head. These valves are used in p-90 heads by folks who are doing the head shave/cam tower shim modification that is very popular with p-79 or p-90 heads: the head is shaved 080 to raise the compression ratio, the cam towers are shimmed up 075 to keep timing chain tension correct,, and the long-stemmed n47 valves are used to keep the lash pad thickness and cam lobe wipe patterns correct. If you are planning to use your head for an NA build then this is a great option but if you are building a turbo motor or an NA motor with an unshaved head then no, you don't want to use these valves.
If you Google SI valves you will find that high quality brand new undercut swirl polished valves are not that expensive.
  • 3 weeks later...
