rb block height
bluez
hey guys thanks, the reason i ask rb24 or rb23- they keep on mention 4agze piston with 20mm pin height. so if i add it rods 121.5+stroke 36.85 or 73.7/2+20mm pin height =178.35 so it would be 188.35-178.35=-10 does this make sense or i am doing it wrong.
Are you sure the 4agze have a 20mm pin height - that seems too low - you could not fit 3 rings into a piston at that pin height without having one of them going around were the pin is ie the oil ring around or below the pin location.
I believe a stock 4age has a 20mm pin but the pin height is 30.5mm I believe the 4agze has a lower pin height by 1mm to lower the CR for the supercharger so that makes a 20mm pin with a height of 29.5mm. So the piston needs to have the pin hole increased to 21mm this does seem to tie up with other threads on Skyline websites when googling RB24's
So if the pin height is 29.5mm then you get 121.5 + 36.85 + 29.5 = 187.85mm so the piston is below the deck by 0.5mm
hey thanks i did it wrong, you are right the pin height is 30.5 and i check out other piston to see if it would work and the closes was a b16a turbo piston, the pin diameter 21mm and the height 30.99 or 1.185 and size is 81mm what you think thanks.
That would put you at postive deck height by my calcs so you will need a thicker head gasket.
I would PM Greenmoster80 on this forum as I believe he starting building a RB24DET some time ago - see http://forums.hybridz.org/showthread.php?t=112825&highlight=rb24
If you want to replicate the L24 specs 83mm and 73.7mm (ie RB26 crank) then I think you best look at sleeving a block either a RB20 up or RB25 down as taking a RB20 out from 79 to 83 would leave the wall too thin.
