Question on picking fuel injetors
Dilligas
I'm building a motor for my '77 280. F54 block w/flat top pistons, a P79 or N47 head (any pros and cons on the head would be great), 60mm tb with a matched bore N47 intake, .490 280 duration cam, headers and a Palnet rail. Now, upon searching I have found out that my stock injectors won't support the setup nor will the stock ecu. Correct? I also found that 280zx turbo injectors are 260cc. Will an oring style low impedence injector from injectors4u with the same flow rate sufice? I read "LineC" sticky on injectors but is there a formula if you don't know your end horsepower and does compression figure in as well?
