What size is the original metal turbo line
Noddle
Thank you all,
I have the banjo bolt and fitting, I'm planing to use some brake line to make this (from my wrecked MR30), one end has the flare , the other end will be silvered soldered onto the banjo fitting.
I got my Tee now, went to the local hose fitting place, they had all the bits in stock to make it
Nigel
you might want to reconfigure your line. yours looks like it might be stcking out on the turbo end. here is a pic of the original
Thanks for that,
If you look at these pictures, the turbo sits out a little further (1/2 inch spacer used), and I didn't want to try to bend the metal line to sharply (It was all bent by hand, no tool used except for the leg on the trampoline)
also if you are wondering about the sump, it for my 240K, not 'Z', see pic.
Nigel
