Mikelly Posted April 16, 2000 Share Posted April 16, 2000 ....New starter solenoid by Summit requires a metal surface to be bolted to....Or you have to run a ground strap... That was the problem with the hard starting. Now it cranks fine, no problem. Didn't have to run 0/1 wire from the rear, but I did go ahead and run an additional 0/1 ground at the rear where the battery box bolts in. Now onto bigger things! Mike ------------------ "I will not be a spectator in the sport of life!" mjk Quote Link to comment Share on other sites More sharing options...
