z31 302 swap
Guest Hatchbaby88
  • 2 months later...
If you dont mind me askin why ditch the vg30e or the vg30et you have? As far as swaps go there is no kits for the z31. Unless you chose to go rb and get lucky enough to find all the parts from a 200zr to have a true "bolt in" swap. But any swap is possible as long as you can make you own x member etc. but if you dont have a welder then i would stick with the vg. A shop will take you to the cleaners to put a 302 in. but if $ is no object then do what makes you happy.
