will stock 280zxt clutch hold up?
Guest bigjim240z
Guest bigjim240z
im putting a l28turbo motor in my 240z and will use the new stock clutch thats on the engine..(has 1000 miles or so on it)..will a stock clutch hold up???.i plan on running some more boost with an intercooler and a little drag racing might be in order too....thanks for any info!
Yeah the stock clutch will hold up ok. Your next upgrade is the 300ZX single turbo, which I what we all used in our 240's with turbo engines way back when.
If you have a BW, you can upgrade to the 300ZXTT pressure plate and have the flywheel redrilled to fit at a machine shop, which is what I have done. You have to do a little tweeking inside the bellhousing.
The best reason I have for going this route is you can get a 300ZXTT clutch at any nissan dealership, and if you have some one off custom super fly deal, you are sunk if you are not in your home area.
