cuebandave Posted February 4, 2009 Share Posted February 4, 2009 Hi, Can anyone help?..... '73 240 zed with two puddles of water in the footwells - has anyone had similar problems and whats the cure - is the water coming in through the scuttle plate? as now lost the power of my repeaters (water in the loom?)..... any advice welcome. Quote Link to comment Share on other sites More sharing options...
drmiller100 Posted February 5, 2009 Share Posted February 5, 2009 normally windshield seals in bottom corners Quote Link to comment Share on other sites More sharing options...
SteelToad Posted February 5, 2009 Share Posted February 5, 2009 ^^^ yeah, check those seals. This is my zx, but rust is rust Quote Link to comment Share on other sites More sharing options...
zgeezer Posted February 5, 2009 Share Posted February 5, 2009 This is a common issue and there are several posts on this forum that address it; just do a search. Other than leaking at the corners of the windshield, here are some others. If you have air conditioning, check to make sure the water that condenses on the evaporator coils is directed outside the car. Early Z's with aftermarket A/C will often leak water onto the footwells. Finally, pull the louvered plate that covers the windshield wiper motor and mechanism. Note that on each end of that cavity drains into a small hole and then down a rubber drain onto the ground behind the fender. If these drains are plugged with debris... usually tree leafs- water will back up and rust out the seam. Water, then will enter the footwells through the seam. Hope this helps. g Hi, Can anyone help?..... '73 240 zed with two puddles of water in the footwells - has anyone had similar problems and whats the cure - is the water coming in through the scuttle plate? as now lost the power of my repeaters (water in the loom?)..... any advice welcome. Quote Link to comment Share on other sites More sharing options...
ckolander Posted February 5, 2009 Share Posted February 5, 2009 ^^^ yeah, check those seals. This is my zx, but rust is rust Where did you get a picture of my car??? Quote Link to comment Share on other sites More sharing options...
garvice Posted February 5, 2009 Share Posted February 5, 2009 When you pull the louvered cowl panel, also check for screw holes. I checked all the usual parts that leak, but then realised a previous owner had tried to mount something inside the cabin and had screwed straight through the horizontal panel leaving small holes for the water to get in. Quote Link to comment Share on other sites More sharing options...
