Shifter lever location
takayuki
Hi,
I have a 1971 240z with a 5 speed swapped in. On a stock 240z with a 4 speed, does the shifter lever sit in the middle of the cut-out or does it sit like the one i have (pic below)? Anybody have an idea what transmission i have? I have a l28 from a 82 zx.
Since my computer doen't allow me to see your picture, I can't identify your 5 spd. However, I've install the close ratio 5 spd from a 1983ZX in my 1970 Z and the shifter will not be centered in the stock 4 spd location without modification to the shifter and a slight trim job at the front of the sheet metal tranny tunnel opening. Basically, I took the stock 5 spd shifter, cut it with a long angle (for maximum welding surface) just above the pivot thru hole, calculated my desired position for the shifter and bent up a 5/8" heavy wall piece of 4130 tubing and welded it in place. It turned out perfectly and have had no issues in 7 years of use. I did have to do some custom sheet metal fabrication so the inner shifter boot would work....! Hope this help you out a little!!
Tom
