s30 rear brake conversion question
OK so i have read and read to the point that i am lost . Ther are so many formulas for rear brake conversoins I have bought the 87 maxima brackets [flat heavy ones] i thoiught my 1981 280zxt calipers would work [WRONG] my question is do i need the 240sx calipers and rotors ? and maybe a spacer? please someone post or pm me the parts that i need and what year to get them from . thanks Greg Autosports
Maxima bracket/280zx caliper swap
Description: Using '85-'88 maxima rear caliper brackets, 280zx rear calipers and rotors to convert rear to disk. Source of parts would be mainly junkyard, and you would have to either remove the stub axle (don't do it unless you absolutely have to) or cut out the drum backing plates to install. The downside is sourcing your own caliper brackets at the JY, and then REMOVING them. You will likely need cordless power tools to do so.
Motorsport auto sells their bracket swap kit, which is CNC'd maxima brackets here. It is $320, and does not include rotors, pads, and calipers. You have to source your own.
from: http://forums.hybridz.org/showthread.php?t=104735
Yes but my 1981 280zxt rear calipersa dont bolt up to the maxima brackets . The bracket bolt pattern is about 1 inch wider. Also what rotor [stock 280zx ] Are the 1981 zxt calipers different than the 82,83 zxt? If someone can post what caliper what rotor and what year these parts need to come off of that would be a big help thanks Greg
