Ga_Z Posted February 17, 2009 Share Posted February 17, 2009 I have a problem. I finally got my Z running after a tank, line cleaning and a new Walbro pump. This thing has been setting for years and i was surprised at how easy it started. But it does not rev past 2K unless I get it up to 1500, back off, rev it to 2000, back off, you get the idea. It smells rich. It backfires through the mass airflow and pops. If I floor it the engine just bogs like the switch is cut off. I know a tune is needed but I wondered if anyone else has had the same or similar problem. I did a few searches but didn't find anything with answers. maybe I searched wrong. I'm going to keep searching. Should I do a tune up first or does this sound like another problem? Possible MAF sensor failure? I'm trying to be as accurate as I can but am I jumping the gun? Thanks for your help Quote Link to comment Share on other sites More sharing options...
Ga_Z Posted February 21, 2009 Author Share Posted February 21, 2009 Ok, I got the FI bible and read it. Turned out is was my fuel pressure regulator. My question is now where can I find an adjustable type at a good price? Also, all of the local auto parts store only carry Autolite and Champion plugs for my Z. I would like some NGKs. Got any suggestions? What do you guys use? Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted February 21, 2009 Share Posted February 21, 2009 Honestly I would get the auto lites for now, youl be dissapointed wehn you buy the ngk's nd foul em up quickly do to the car not running right. Ive got a good working stock fuel pressure regulator if you want it, 15$? But I would also do a complete tune up if it has been sitting for a long time like you implied, plugs, wires, cap rotor, all fluids flushed, Oil change... the works Quote Link to comment Share on other sites More sharing options...
Ga_Z Posted February 24, 2009 Author Share Posted February 24, 2009 Thanks. PM me and we'll do a deal. I would rather go used for now. I will be doing the tune this weekend. I bought some Seafoam to use before the oil change. I have another set of Champions I found that I'll use for now. Once it is running good I'm on to the brakes and suspension. Quote Link to comment Share on other sites More sharing options...
