240zJon Posted February 18, 2009 Share Posted February 18, 2009 I am the proud new owner of a 72 240z with a l28 running round top carbs.I need to get air cleaners for it and I don't know what to get. I found a 260 air cleaner and I don't know if it'll bolt up. Any ideas ? Quote Link to comment Share on other sites More sharing options...
JSM Posted February 18, 2009 Share Posted February 18, 2009 Likely no. Did you look at it? The 260 has square intake on the carbs and the 240z has round, if you have round top carbs. Quote Link to comment Share on other sites More sharing options...
zforce Posted February 19, 2009 Share Posted February 19, 2009 If you want to use the 260Z air cleaner with the early SU's Z therapy has an adaptor. Quote Link to comment Share on other sites More sharing options...
zcarnut Posted February 19, 2009 Share Posted February 19, 2009 Use the 1970-72 air cleaner assy. The “flat top†carb air cleaner housings (both the 1973 and 74) has less height and therefore the air filter has less surface area and will be more restrictive. Using a 1970-72 air filter in a later housings will result in a gap between the cover and the back plate. Quote Link to comment Share on other sites More sharing options...
