Guest empracing Posted November 19, 2002 Share Posted November 19, 2002 bearing in the back of the box when you select the gears in the back of it the clearance opens up and the noise all but disapears been there done that....twice actually! at least there ez boxs to work on Quote Link to comment Share on other sites More sharing options...
Mike C Posted November 19, 2002 Share Posted November 19, 2002 Or the countershaft bearings are going out.It's fine in 4th because it is effectively direct drive, you aren't sending any power through the cluster gear set. If it's a 4 speed I'd just find another one. Should be cheap. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 20, 2002 Share Posted November 20, 2002 Help?! I drove the Z today after a few months. It used to have a light knocking sound coming from the tranny and it could be felt in the shift knob. Today I was running errands in the Z I drove it and it sounded like normal, until I came out of the othodotics (sp?), and started it up and drove out of the parking lot it starting making this LOUD whinning (like a Star Wars special effect or something) when I was driving. so I kept the revs down and put into fourth gear as much as I could, it drove like normal in fourth, until I got home and put the car in the garage. Whenever it was idling I reliezed the knocking was gone. I have a feeling it is a bearing, but that is only a guess! Can anyone help me out? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 22, 2002 Share Posted November 22, 2002 But I think the cluster shaft is in contant mesh with the input shaft. I think it could be the pockect bearing in the rear of the input shaft because the output and input are spinning together it is no longer a bearing it just revovles with the 2 shafts. And in all other gears the input and output are at different speeds. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 23, 2002 Share Posted November 23, 2002 What would happen if I go to a local junkyard and buy a tranny from the dependablity standpoint Then does anyone have a 4speed tranny laying around that they would like to get rid of(sell)?? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 23, 2002 Share Posted November 23, 2002 Marshall ...if you have not done so...Check the oil level. I have solved many a tranny problem by adding oil to a tranny. The trannys that went out on me did not whine.. they screamed and clanged so much a trained excorisist could not calm. Quote Link to comment Share on other sites More sharing options...
Mike C Posted November 24, 2002 Share Posted November 24, 2002 The cluster is in constant mesh with the mainshaft gears. When the bearings wear/fail, the clearance increases, this causes it to whine. If this IS the problem, eventually it fails because there is insufficient contact between teeth to carry the load. Since it is quiet in 4th, seems more likelly a cluster gear problem rather than a mainshaft bearing problem. Either way, if it is a 4 speed, I would just get another one. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 24, 2002 Share Posted November 24, 2002 Alright cool hey I'm 19 I just graduated from UTI and I was trying to test my knowledge. You probably have way more experiance with these tranny's then I do. Is that a common problem I really odviously don't know. What causes it to get quieter in 4th, any explaination will help. I've been taught but an no where near experianced. Quote Link to comment Share on other sites More sharing options...
Mike C Posted November 24, 2002 Share Posted November 24, 2002 4th gear is direct drive, the input shaft is locked to the mainshaft with a slider/synchronizer assembly. No power is routed through the cluster gear but load is still on input shaft bearing and tailshaft bearing and bushing. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 24, 2002 Share Posted November 24, 2002 It is a very loud scream that I was afraid to go above 2000 rpms. I put some gear oil into it a couple months ago and it seemed to queit the knocking sound. I thought I was out of the woods until it started to scream at me!! Thanks for all of your replies! Mark Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 25, 2002 Share Posted November 25, 2002 I will check the tranny oil level again tonight! Thanks Mark Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted November 25, 2002 Share Posted November 25, 2002 I have 2 four speed, if thats what your running, that I need to get rid of to make space. One I pulled off my car not but 8 months ago, no screaming....other four speed I got with the car. I assume since the previous owner didn't discard its still good. I have pics I can send if interested. reason for removing the one out of my car was to upgraded to five speed. Will let go for low low price. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 29, 2002 Share Posted November 29, 2002 I am all ears!! Give me an email, please! Thanks Mark Quote Link to comment Share on other sites More sharing options...
