ansell Posted March 8, 2009 Share Posted March 8, 2009 Ok i am looking for help or any ideas,abouth my problem, i was driving my car a couple of days ago and it died on my i tried to start the car back but it won't start like it ran out of gas,but the gas tank was almost full. i call the tow truck they got the car home,after a while it started but it was shaking and when you accelerate it was misfiring,it died again and whenever you try to restart the car the battery will sound like it is discharged but when you let the car rest for a couple of hours it will start again but doing the same thing .shaking,misfiring and it will die so far these are the parts i have replaced, i forgot is a 1977 280z fi. 1.fuel pump 2.air flow meter 3.the distribuitor rotor any ideas would help thanks..... Quote Link to comment Share on other sites More sharing options...
kiwi303 Posted March 8, 2009 Share Posted March 8, 2009 fuel filters, pumps can't pump if they can't get the fuel to move it around. you don't specify type belond "car", S30 L6 I presume? Carb or EFI, so if EFI, try cleaning contacts on the injector harness. Others should pop up with other ideas in due course. Quote Link to comment Share on other sites More sharing options...
kiwi303 Posted March 11, 2009 Share Posted March 11, 2009 had any luck getting it to go again? Quote Link to comment Share on other sites More sharing options...
ansell Posted March 11, 2009 Author Share Posted March 11, 2009 (edited) No is not working yet the fuel filter is new,all the injectors are working. also the throttle valve switch is new,i really can't figure out these problem these time. i usually fix the cars my self even know im not a mechanic, but im pretty sure is something electrical i guess my z has to visit a real mechanic thanks for the help anyway. Edited March 12, 2009 by ansell mistake Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted March 12, 2009 Share Posted March 12, 2009 Put a Fuel pressure gauge on it. Sounds like you have a clog. Quote Link to comment Share on other sites More sharing options...
ansell Posted March 13, 2009 Author Share Posted March 13, 2009 I will try to put the fuel pressure gauge tomorrow,and i tell you something maybe you are rigth because last time i check the fuel pump it sound like it was working rigth but the pressure seems like its not strong enough. i will check on it and i let you know thanks.... Quote Link to comment Share on other sites More sharing options...
