water temp connector ('79)
ok so i was testing the thermotime switch instead of the water temp sensor when i was checking the into possible solutions to my problem here http://forums.hybridz.org/showthread.php?t=144072
so i try to unplug the water temp to test it but the connector snapped off. i thought what the heck is this?
then i notice that the PO (aka Mr.STP) removed the old car side connector spliced in a little bit more wire (to reach i guess) and soldered and hot glued the wires directly to the water temp sensor.
so i need to replace it either way because the guts of the thing came out and it was probally bad to begin with but i am going to put a real connector on it
i just need to know does it matter what wire goes on what pole on the sensor or does it not matter just as long as it makes a circuit?
and also i cant find the thread that talks about what cars have the good connectors (the squeeze kind) so if any one knows off the top of their head what car has those that would be great as i am going to the j-yard tommorow
  • Administrators
Nope. Not polarity sensitive.
Most GM cars have what your looking for.
