WizardBlack Posted June 1, 2009 Share Posted June 1, 2009 You clearly have some bits that can flow better up top and some bits that are out of breath by the time the turbo spools. It seems like a lot of stock head/manifold turbo cars I've seen; just a bit bigger turbo costing you some spool, perhaps. One observation; your timing looks too high at idle. Just as timing typically picks up a few degrees after peak torque, so too, does timing drop low as you get below 2krpm or so. The engine is moving so slowly; you don't need that much timing. Look at the point 2750rpm/105kpa. Note how it tapers more retarded as you go down on the map (higher boost); mirror that to it's left as well. Quote Link to comment Share on other sites More sharing options...
