Jesse OBrien Posted March 23, 2009 Share Posted March 23, 2009 I really wish I had some pics on hand, but I guess a description will have to do. I just put an s130 clutch master cylinder in my s30 to replace the VERY badly bent and seized one that came in the car. After I had everything bolted up, the shaft just kind of ... fell out ... of the master cylinder, and it really isn't even long enough to reach the pedal. Is the shaft in the s130 MC shorter than in the s30 MC? Does anybody know what the shaft length actually is? Quote Link to comment Share on other sites More sharing options...
ezzzzzzz Posted March 26, 2009 Share Posted March 26, 2009 I'm guessing no one has done this or had that problem. Your using the old push rod? Can it be lengthened? Any reason why you chose to use the S130 MC or the S30? Quote Link to comment Share on other sites More sharing options...
blue72 Posted March 26, 2009 Share Posted March 26, 2009 http://forums.hybridz.org/showthread.php?t=112496 Quote Link to comment Share on other sites More sharing options...
Sideways Posted March 26, 2009 Share Posted March 26, 2009 http://forums.hybridz.org/showthread.php?t=112496 Psst. he said clutch master. Quote Link to comment Share on other sites More sharing options...
blue72 Posted March 26, 2009 Share Posted March 26, 2009 DOh! you are right. Now to activate my search function! Actually, since we're talking about the clutch MC rod, you can just weld on an extension piece if it isn't long enough. Well, if you've got access to a welder or some threaded bar stock. Quote Link to comment Share on other sites More sharing options...
jintei Posted March 26, 2009 Share Posted March 26, 2009 i had the same problem on mine, the shaft is indeed shorter. just welded a pair of nuts on the adjustable rod end (the threaded piece where you pin the pedal Quote Link to comment Share on other sites More sharing options...
Jesse OBrien Posted April 2, 2009 Author Share Posted April 2, 2009 Since I lack a welder and have a spare s130, I may just see if the s130 pedals fit in the s30 chassis. Quote Link to comment Share on other sites More sharing options...
stevo_gj Posted April 3, 2009 Share Posted April 3, 2009 Since I lack a welder and have a spare s130, I may just see if the s130 pedals fit in the s30 chassis. I purchased a 280zx pedal box for my 260z, and the pedals weren't interchangeable. I ended up having to get a proper 260z box. Quote Link to comment Share on other sites More sharing options...
caen fred Posted April 4, 2009 Share Posted April 4, 2009 I switched the rods... Quote Link to comment Share on other sites More sharing options...
