what dizzy???
RA64
So im in the middle of a swap an need to know what dizzy to use. im putting in a l28 but do i use the dizzy from the l24 or l28? the l28 was EFI.
Iv tryed to search for this but no luck. I was also thinking of useing the PerTronix Ignitor. So to give more info on what im doing... n42 block, N42 head, it will be carbed SU or AZC holley. going to put flat-tops in when $ comes around later.
Either go with the Pertronix or find a '79-'80 ZX dizzy in a boneyard with an E12-80 module and run it. Those are probably the two easiest/most cost effective ways of doing it.
The 280Z distributors use an ignition module that's mounted inside the passenger compartment. The later N/A ZX distributors have a different 'matchbox' ignition module mounted on the dizzy, an E12-92 or E12-93. They can be used, I've got one running properly on my car now, but it takes some thinking to get around the timing retardation built into the later units. Another good option is to run the Ford EDIS system but that's probably a bit more complicated than what you're looking to do.
Come to think of it, I've got a spare early ZX dizzy that I rebuilt last week, but I haven't tested to see if the E12-80 module is still good.
