Guest Pegasus76 Posted January 25, 2003 Share Posted January 25, 2003 I just replaced my clutch today and I have a T-5 transmission. I put 4 quarts of Dexron fluid in there and I put a 10" clutch...And it uses 73 half ton truck pressure plate don't ask... (73 camaro engine) but yeah...So now the clutch feels a lil weird and if I let out a lil bit it jumps (considering I am used to letting it out almost all the way I got a lil scared) but anyway...4th and 5th gear go in real smooth but 1st and 2nd is really hard. What should I do to adjust that or is it normal? Quote Link to comment Share on other sites More sharing options...
Mike C Posted January 25, 2003 Share Posted January 25, 2003 Because the new clutch dis is thicker than the one you replaced, the length of travel of the pedal before release has been reduced. I don't think there is any adjustment to the GM hydraulic linkage. Drive it for a couple of days and see if the feel and your comfort improve, then reevaluate. Quote Link to comment Share on other sites More sharing options...
