forced shift
I have a '73 240z, just changed the clutch (it was my first one) and I have trouble getting the shifter into gear. 1st gear is the worst. I had to bleed the clutch because I put a new slave cylinder on it. when I put the shifter into 1st and the clutch is completely depressed, the car creeps forward when the clutch shouldn't even be engaged.
I just did a thorough bleeding job, and the pedal rod is maxed out. I peeked into the dust boot where the lever goes into the transmission and had a friend depress the clutch, it appears the the throw-out bearing is making contact with the pressure plate, however it drives as though I dont have have a clutch.
